I'm not of much help but did you get the cat hot before taking the test? You want to get the cat hot and not let the car sit more than 10 minutes before it gets tested. Maybe try some seafoam through the gas tank and intake system to clean the injectors and intake/exhaust valves and piston tops. If you need to I have heard a bottle of 90% rubbing alcohol dumped in a half tank of gas will help clean stuff also and help you pass
