Exhaust is making hissing sound, worried about the cat.
Johnny .45
Pro Hoonage Expert
I have a 2000 EX coupe, manual trans. A few months ago, I lost my cat. The engine lost power over a couple days until it finally died. It sounded "off" at idle before it died, but that was it. I had it replaced, and it's been fine since then. A couple weeks ago, I suddenly noticed a "hissing noise, that sounded like an air leak. It got louder the more you pressed the accelerator, regardless of what RPM's the engine was running at. It also seemed to be losing some power. The sound was definitely coming from the tailpipe.
After a few days, I accelerated from a stoplight at WOT. Once I got to about 6,000rpm, suddenly it made a loud sound like a backfire. The sound was gone instantly, and the engine felt more powerful. It seemed slightly louder too, but not sure if it's louder than it was before the sound started, or if it had just been getting quieter over those few days. It seemed as if something had been plugging it up, and the backpressure finally cleared it. I figured "all's well that ends well", but have kept in in the back of my mind since then.
It's been a few weeks since then, and suddenly it started making that sound again. This time, I remembered what had happened last time, so I tried accelerating again. Sure enough, it did the same thing, only not as loud this time (I didn't wait for the hissing to get as bad this time before I tried it).
I am worried about the cat; after the original went bad, I had planned on having someone look at it and to see if they could figure out why it had gone bad before, but I never did. Only, the symptoms are entirely different this time, and the only things I can find out about cats clearing themselves is when they blow their innards out the tailpipe from the backpressure. If that had been the case, I think I'd have noticed it, and why would it plug up again if the innards had blown out? There'd be nothing to plug up.
Since I've got it, I've noticed that it seems to make a lot of soot at the tailpipe, more than normal, and it goes through quite a bit of oil, although it doesn't leak and I see or smell no signs of oil in the exhaust (unless the soot is a sign). Can oil ruin a convertor? I hear about running rich being bad for them, but nothing about oil burning clogging them up, or about them fixing themselves. Kind of puzzled.:?:
tekfoc
On the old engine I had lots of soot also out the exhaust.
Burning oil , did a compression test had 2 dead cylinders .
Replaced engine.
The cat is your least of your worries do a compression check . Back firing is probely dew to oil fouling up plugs and injectors .
Johnny .45
Pro Hoonage Expert
It wasn't a backfire. It SOUNDED like a backfire, but I don't think it was. Like I said, it was making that hissing noise in the exhaust. I revved it up under load, it went BANG. The noise was gone immediately, the power was back. I might be having compression problems, but that's not what made the hissing noise or the bang, and that wouldn't explain why the power came back and the exhaust got louder after it happened. I believe it was something blocking the exhaust blowing out from the backpressure. The second time didn't even sound like a backfire; the hissing started again, so I revved it up. This time it was more like a "whump", and again the hissing was gone. Power was back.
I have checked the spark plugs and those are fine. It RUNS great. It may well be that it has bad piston rings and that's where the oil is going. Since I posted that, I've read that burning oil definitely CAN plug up a cat. I'm hoping that it's just worn valve guides leaking oil into the heads, since that's easier to fix. Until then, I'm going to assume it's the cat trying to plug up from burning oil, even though all the pieces don't quite seem to fit together.
So yes, the greatest of my worries is that the engine is bad, but I'm pretty sure the symptoms are from the cat, being caused by burning oil (even though I can't see any sign of it burning oil...no smell, no blue exhaust).
Anyone know what it takes to swap a B series into my car? If I have to swap engines, I might as well do it right! =)
CEL codes?
Have you removed the cat to see whether the substrate is melted?
Johnny .45
Pro Hoonage Expert
No, but I plan too soon. I just wanted to know if the symptoms matched anything anyone else had experienced before I did the work, and I need a garage to read codes. I work nights, and it's a pain. I wouldn't have even asked if I had read about burning oil causing cats to fail first. I just thought it didn't act like the first time it happened, so I hoped it was something else (and maybe it is, who knows).
TokyoSkies
Boost Junkie
Follow RonJ's advice, and while you're at it, see if the muffler is packed. If it's the stock canister-style muffler, they can get packed. This kinda sounds like the culprit.
