Ok, well winter is comming and its time for something new. I hate to do this but its been fun. I am the 2nd owner of the car. and since i have had it its been nothing but fun. The car has been Garage Kept, A local shop here in Columbus Slowmotion Motorsports has done a professional motor swap, and Turbo kit on the car. The oil has been religiously changed every 2,500 miles!!! NO Leaks, does not Burn a drop of oil!! Compression tested 210psi PER CYLINDER, and i have all paperwork and recipites from every dollar in the car totaling over $10,000!!!
-PLEASE SERIOUS BUYERS ONLY-
CONTACT: Steve Monte
-Email: TURBOHATCH87@yahoo.com
-Phone: 740-972-1705
Please BUMP after viewing.
the prices listed on the side is what i Paid for that part, and have recipets for all!!!
Car made on pump Gas (7lbs) 290WHP!!! and 220WTQ!!!
It is extreamly reliable and well maintained, and Conservatively tuned at 11.0-11.5 A/F
-CLEAN TITLE-
-1996 Honda civc CX hatch
-Milage 154,xxx (on body) (purchased last year with 141,xxx)
MOTOR:
-JDM B-16 with all papers $2,500
TURBO KIT:
-Slomo Equal length Ram Horn manifold stainless (lifetime warrenty) $800
-Garrett T3 60-1 Turbo with STAGE 5 Wheel $700
-Tial 38mm Wastegate with 7lb spring/ also have 5lb spring(driven on daily) $220
-Stainless dumptube Ceramic Coated $75
-3'' Downpipe tapped for wideband and stock o2 Ceramic coated $150
-2.5'' Intercooler piping With Vibrant Couplers and T-Bolt Clamps $400
-Percision 350HP intercooler $230
-Stainless braded Oil return and feed with Jegs AN fittings $150
-Skunk 2 intake manifold ported 70mm $200
-Green 4'' Turbo Filter $40
-Greddy Type S BOV $200
-3'' Tubo back Exhaust with DC spiralflow muffler $700
FUEL SYSTEM:
-Warbro 255lph pump $90
-AEM Hi flow fuel filter $75
-AEM Hi flow fuel rail $100
-Percision 880cc injectors $280
TRANS:
-CTR (LSD)
-ACT HDSS- Heavy duty pressure plate $355
-Street Disk
MANAGMENT:
-HONDATA S300 $600
-Chiped P28 $125
-Conversion Harness $75
(This car has been FINELY tuned by a hondata certified tuner, and tuched up monthly!!)
-I have all recipites for tuning alone are over $800.00
GAUGES:
Autometer Pahontom Series
-Boost/Vac 30/30 $50
-Eletric Oil Press 0-100 $50
-Eletric Water temp. 0-250 $50
-EGT (needs probe) $80
SUSPENSION/WHEEL AND TIRES:
-Stock Si Struts with Ebiach Pro Springs
-GSR Strut Bar
-205-40-17 BFG Gforce Sport tires (have Roadhazzard warranty) (90% life left) $400
-17 inch LS Mesh style wheels Black with a machined aluminum Lip $380
BRAKES:
-Hawk pads $50
-Drilled and slotted rotors $100
SOUND:
-Pioneer Premeir 6.5 door speakers $65
-Pioneer Premeir 6 by 9 rear speakers $100
-Acura CD deck
MISC:
-5% tint in the rear and 15% on the front
-Hassport Drivers mount $175
-Polyurathane lower motor mount $25
-Black Valve Cover and Sparkplug cover
-Mesh grille wit "civic" emblem on side
-New napa gold axles $100
-CTR oil Pump $125
-OEM water Pump $100
-OEM Timing belt $60
Engine bay has been WIRE TUCKED and re sprayed looks GREAT!!
Runs and drives Amazing!!!
if you take a min, and add up what i have into this car you will see i have nothing but quality parts on it. MY LOSS IS YOUR GAIN
Pictures:
-CLEAN TITLE-
MOTOR:
TURBO KIT:
FUEL SYSTEM:
TRANS:
-CTR (LSD)
-Street Disk
MANAGMENT:
-HONDATA S300 $600
-Chiped P28 $125
GAUGES:
-GSR Strut Bar
BRAKES:
-Hawk pads $50
SOUND:
-Acura CD deck
MISC:
-CTR oil Pump $125
Pictures:
