how do you fiberglass a dash, or can you strip the upholstry off and just paint it
boostedb16 New Member Registered VIP 5+ Year Member 10+ Year Member Dec 6, 2005 #1 how do you fiberglass a dash, or can you strip the upholstry off and just paint it
YoungKadafi Redundant security Registered VIP 5+ Year Member 10+ Year Member Dec 7, 2005 #2 sand ALOT! then some more, and then just a little bit, thick primer filler, then paint, sand sand sand sand then clear, then sand sand sand and then a lot more sanding all using 1500 grit. use rubbing compound a few weeks later about 5 times.
stealthy 4 Doors For More Whores Registered VIP Registered OG 5+ Year Member 10+ Year Member Dec 7, 2005 #3 you only post how to do something in the how to section,you dont ask.questions are technical.failure is yours.
Tom honda.co.jp Registered VIP Registered OG 5+ Year Member 10+ Year Member 15+ Year Member 20+ Year Member Dec 17, 2005 #4 Since this is not a how-to it has been moved!
cgpEJ6 noob Registered VIP Registered OG 5+ Year Member 10+ Year Member Dec 17, 2005 #5 fiberglass dash = yuck
