right... but if you ground it to the low beam... then they will turn back on when you put the high beam onitsmycookie said:when the headlights are turned off there is no power going through the power side of the headlights, so it acts as a ground. when u turn them on power runs through it. so the city lights will turn off since it will have no ground left. both wires leading to the city light will be +, and therefore will not flow electricty.
i spose, but i never use my high beam setting.BlackHope121 said:right... but if you ground it to the low beam... then they will turn back on when you put the high beam on
not necessarily a problem..
I would have done it this way too before but you cant even see my city light when my headlight is on
h-i dizzy
