First swap 95 B18b to 98 EK need a bit of help!! PLS!
jayndee
hey first big swap.. running into a couple snags.. ok first OBD1 engine to OBD2 car.. got conversion harness.. what can i do about dizzy plug in and a couple other plugs... what part of harness off the B18 can i use?
did alot of searching cant seem to get a detailed enough answer...
and the whole rolling chassis of the integra ( shocks, control arms, rack and pinion system) can i use the whole thing? i know the shock towers are the same, bolt right up but EK is not power steering and not the same front subframe so hoping i can maybe use the tie rod ends ... or if EK steering will bolt right up?
im sure ill have a couple more questions as i progress but thanks for the help in advance! :shock:
