Flywheel w/ boost weight??
j_fukin_t
will a 8 lb flywheel be a lil to brittle w/ boost, btw its gonna be the greddy kit for Si's at the most 8 psi, or should i look into the 12lb one?? thanks in advance
FRODO
11lbs sounds good.
j_fukin_t
either one, which would be the better, obviosly steel would be cheaper, but which is the better choice, and which is going to be more durable??
King Bob
The life'o Riley
Stay away from aluminum. It can shatter go with the heaver steel better safe than sorry.
Handlebars
None Taken.
im running a 9lb findanza, its worked out fine for me.
banzai
Exit Speed Garage
I have an 8lb aluminum
j_fukin_t
so a heavier aluminum will do the trick, honestly i'll never do anymore than the bolt on kit, so now my next question is BRAND??
stealthy
4 Doors For More Whores
i think you will be ok with aluminum considering the setup,as for the weight,there is no right or wrong answer.there two schools of thought,and both heavy and light flywheels have an advantage and disadvantage....
j_fukin_t
so what would be my disadvantages of going w/ a 8 lb or a 11 lb aluminum
stealthy
disadvantages of a lighter flywheel will result in more rpms lost between shifts,however,as opposed to a heavier flywheel,you can gain them back quicker.it is up to you on which weight you go with,either way,your gonna have to learn how to launch with it,bc it will in fact be totally different than normal.so,if you've never driven with a lightened wheel,id go with a mid weight,such as 11lb,however,just like anything you will be able to learn to drive with any,so you may dive right into an 8lb.the choice is yours ultimatly
