FMU or Bigger injectors
GSROWNSU
Hey guys i'm gonna boost my gsr and built my kit myself (should save me alot of money) i'm only going to run 6-7 pounds tops....everyone is telling me at those levels i should be fine w/ stock compression....but what should i go w/ a fmu or bigger injectors....i'm thinkin fmu but because it increases fuel pressure i'm just worried about somethin becoming over pressurized. What do u think i should go w/.
GSROWNSU
anyone feel like helpin?
nd4sped
Moderator
Eventually you are going to max out your injectors. So I say injectors. Plus I dont like FMU's. FMU's were the s**t back in day. Just get a piggyback system, aka APEXi VAFC to control the injectors. Plus there is a lot more you can manage with it.
Personally I like the APEXi unit. Everyoen says no to it but thats becasue they really dont know much about it and rely on other peoples knowledge.
Otherwise get a chipped ecu or a standalone. Standalone is the best especially in teh long run.
bizoneoeh
Ex-Gang Member
yup, I say get some bigger injectors as well. I have a safc2 with 310's and they work fine
io_303
NIFOC
get yoyself som 440 and a nice standalone or piggyback system. You can go cheap like me and just chip your ECU, or be like returnoftheking and follow his quote "I can afford cheap parts"
Destroy
bleh, get the fmu if your running only 6 psi...get a fuel pump
i remember people running 11's on fmu's back in 97....memories
banzai
Exit Speed Garage
if you bought bigger injectors, how do you plan on using them without fuel manag?
cberman
dude save up
itll be so much cheaper in the long run if you do ur engine management correctly the first time
im taking my car in on wednesday to get it tuned with cromepro
D Grade
NOT Banned
Injectors and an SAFC 2 (if you're on a budget). SAFC's are cake to use, plus the ver. 2's feature a knock reading (which with boost, you WILL want). If you find tuning to be too challenging, then buy a wideband on top of that.
