foglights aren't working help!!
civicdrvr
ok i need some help fast here !!i have a 96 sedan with stock square foglights that i put in about 2 months ago have worked wonderfully up until now yesterday i noticed they weren't working soo i got up went to school and now i have been outside for about 1 1/2 hours trying to figure out why they aren't working, i have my front bumper off and part of my dashboard off looking at everything i can to figure out whats wrong ,i checked the fuse on the foglight wiring,i check the bulbs which still seems to be good, i disconnected the plugs and pluged them back in but still nothing ,the relay switches over but can there still be a problem with the relay even though i hear it switch over ???is there another fuse im missing with all the other fuses ???i need some help here !!! thanks
civicdrvr
anyone??? please :puppyeyes
civicdrvr
car parts still all over the place ,someones goltta know somthing!
civicdrvr
ok im going to try this again now that it is later in the day and more people must be on!?
96greencivic
#1 in the Atlantic!
How do the prongs look that connect to the housings? Are they corroded? Try cleaning those off. Is the ground still connected?
USDM didn't come with stock squares in OEM. You must be talking about aftermarket right?
BlackHopeDC5
Is Black Again??? :shock:
you may not like this answer but the exact same thing happened to me two days ago.. They were working fine but then all of a sudden both of them stopped working.. But i could still hear the click on and off
I was all depressed and drove to wendys and then all of a suddent they started working.. Give it some time maybe it will work again like mine did :what:
civicdrvr
ahhhh nooo hahaha oh man this sucks!!! lucky lucky you.
BlackHopeDC5
did you install the fogs yourself?
civicdrvr
yeah but aftermarket from honda ,even though mine are replias ,im pretty sure u could get the square or round fogs!
BlackHopeDC5
do you know how to aim them up or down... and yeah clean the spades i did before cause they were all coroded
civicdrvr
yeah there is little spot off to the side of the light where u stick a screw driver in and turn it left or right , im pretty sure that should adjust it .it looks just like the one for ur headlights if u have seen it before?
chow
Its hard to convert KMH
Check the ground wire. :what:
chow
civicdrvr said:
just did seems to be good
did u try moving it to a different location? i had a problem with my fogs once and it turn out to be bad grounding. if thats not it i dunno.
BlackHopeDC5
i just did some trial and error and found out that when you have a bad ground you get the same symptoms. (the clicking but no light output).. i took the ground on and off.
as for the aiming i still have no clue
can you point to it for me becuase i am a fool =)
:what:
civicdrvr
look at it from the front and u should be able to see the spot for the screwdriver,but in your pic its the big white round thing in the 1st pic.im pretty sure that adjusts it .i did it on mine and it moved it some what but just try it out .let me know if u need anymore help and ill have to go and check out the ground again ?? good luck!
civicdrvr
found the problem 10 min before work will let u guys know tomarrow what happened! thanks for all the help
bmoua
check your ground...just installed my fogs last weekend..worked for 2 days and went out....my relay switch wont switch over...still gotta go get a new relay switch...
