forced induction
chadroper
How hard would it be to build a 450 hp B16A engine. I know it is an open deck aluminum block because I had to replace the head gasket. Will the cylinders wobble around inside the block and is there a way to stop it? I have a 1989 Accord DX that has 447 hp at the wheels but it has a closed deck cast iron block with a bearing cap girdle. It also has 2 T-3 turbochargers and the intake tract pressure is 36 psi over atmospheric. (the head is very inefficient so it takes very high boost pressure to make any power). I also spent nearly $8000 on it. Would the B16A be as expensive.
42Steps
Welcome my son....
WRONG SECTION!!!! Go to Engine Tech under forced induction....
Shiznit
Stickin it to the Man
youll need to upgrade your internals tremendously. theres numerous ways to get a b16a to 450hp.
1sckcvc
lemme get this straight.....you have a twin turbo accord?
Destroy
Yes it will wobble, cast ductile iron sleeves will stabilize the cylinders
:thumbup: for the oldschool accord
