front end vibrations
dap8512
from about 60mph on up i have a bad vibration that almost pulsates. hope somebody understands and can help
I_GOT_BOOST
since 06
it could be several things ive had this issue before numerous times......
causes:
bent rim
tires need to be balanced
bad tires may have a bubble
tie rods
axles
aligment
and the most common is that you probably need brakes and or rotors maybe even both
I_GOT_BOOST
since 06
also do u feel the pulsating if you put your foot on the brake pedal at these speeds......................if when slowing down you feel the steering wheel pulsate and brake pedal then its 95% the brakes its not expensive so if i where you i would just replace the rotors and pads and see if it fixes your problem
203CT
Slow But Not Low
^^^this
obracer12
going to put my money on the inner tie rod ends.
But all of the above apply.
