I drive a 95 Civic and i want to change the bulbs of the front lamps, how do you do iT?
THANKS
THANKS
Yeah it should be the same on your 95 Civic, plus don't touch the bulb with your handsanfrey said:i'm not sure if it's the same with 5gen and 6gen, but here goes... i changed mine today...
pop your hood.
unplug the wiring plug from the headlight bulb's rear.
remove the rubber ring (it's big)
remove the bulbs.
put in new bulb. make sure the tab is aligned right when u put it in.
replace rubber ring.
plug wiring.
turn on ur headlights and check.
oh a similar note, any one know how to adjust the headlights? i can't seem to turn the plastic gears with my fingers
