Front right speaker has no power -_-
Blazing angel
For a while now, my front right speaker has had absolutely no power going to it. I simply thought that the speaker was blown, so now, i replaced it with a three way pioneer speaker. It took a while to make enough space for it to fit in, and now it doesn't even work. I'm kinda annoyed now uuh. Any suggestions?:(
Everything else is stock.
xWIREMANx
Use a multimeter and check for continuity between the wires at the speaker and the wires inside the car. Wires that are in the door boot may be broken.
Blazing angel
The wires in the door boot are broken, and i tried for over 2 hours to fix em. No dice
If i get a new harness, will it have both ends of the cable ready to go? (connectors and the cabling?
xWIREMANx
If you bought a new door harness then it should have all the plugs. That however may be harder to replace then running a new speaker wire and definitely more expensive. You could always go to a reputable local car audio shop and have them repair it for less than the price of a new harness.
