fuel injectors
CivicLuv87
Whats a good brand of fuel injectors and what does the cc stand for after the numbers??
AlaskaB16
DOING WORK!
Cubic centimeter (unit of volume. 1 cc is about 1/1000 of a liter). The higher the number, the more volume. Not sure on any specific brands though. I'd go OEM if you're not looking to upgrade.
AlaskaB16
DOING WORK!
Oh.. well if you look under your first post, there is an add for lots of injectors. LOL.. And I meant upgrade as in more CC's, not brand name. Don't get bigger injectors if your motor is still stock. And if your motor isn't stock (boost) and you're asking about injector cc's I think you may need to read up some more or you'll do some damage if you're not careful. As for brand "upgrading", Sorry man. Can't help you. I'd just go OEM so... Good luck!
mymmeryloss
RHD is where its at
Research research research.
What is done to your motor? What are your plans? Y do u need new injectors?
CivicLuv87
I got a stock b18c1 I wanna turbo it but later down the line I just wanna put a few things on there now to give it a Lil more power.
emerican
like said above injectors will not give you anything they dont need to be added untill later if you boost it and when you do then you have to get it tuned.
mymmeryloss
RHD is where its at
Getting bigger injectors is like buying a turbo and not hooking it up to anything.
mc360
boosted hx
ya dont bother putting on bigger injectors until your putting the turbo on, without a tune the car probably wont start or if it does it will run really rough.also the injector cc is dependent on how much power your looking to make so look up a injector size calculator
