Fuel leak Question
Oem>
Just swapped a b16 into my ej coupe. Dropped motor in and threw on the harness ihad (y7 for now) . When i finally got all the grounds connected i turn the key to see if itll crank and when i turn to the III postition right before cranking , gas comes out from my Fuel Pressure Regulator. Using HAmotorsport p28 with b16 map, stock rail. Didnt come with fpr so threw on my Y7 one and changed the o ring, then tired my y8 fpr and did the same thing. Figured since both motor stock psi is 43 that i could use it. Anyone have any idea what can be wrong?
