Hi guys, I recently replace my 96 dx civic suspension with 2 pairs of yellow koni and the lower control arms with function7 (the damn bolts on the OEM LCA broke on me, both side, ended up cut both LCA bushing out, so i got function7 LCA for replacement).
Anyway, as far as handling i think its ok with yellow koni, not much different from the OEM ones, maybe a bit stiffer and more bouncy, i have set softest in front and half circle rear. My question is ...there are popping or creaking sounds from the rear when i go up or down from drive way or high bumps. Are these sounds natural since function7 has energy bushings?
Also should koni shocks make a huge different on the handling? or they need to the assistance of upper, lower tower bar and rear sway bar in order to make a noticeable different in handling
