fuse question -- beep beep!
stolibears
Use your dipstick Jimmy!!
Does anyone know if switching out the 15amp fuse with a 20amp fuse will fry anything from the horn fuse?
Reason I ask is I upgraded my horn and it's a 20amp (makes mad hp gains!!)
I burnt the original honking at some lady who cut me off on her cell and also noticed the cruise buttons didn't work, but the cruise button was still lit (confused?, me too). Swapping in another 15amp fuse and burnt that on some guy going 15 in a 45. So I know that fuse controls the engage buttons on the steering whee as well as the horn button. The only thing I could think that might fry is a possible relay for the cruise control but don't know if there is one.
stolibears
Horn relay:
read through the ole honda manual, cross referenced the part number found what is supposed to be an OE aftermarket brand from Omron (supposedly Denso makes one too), so I'm guessing the ratings should be the same;
1 Form C
Unsealed
20A (NO)/ 10A (NC) @12VDC Resistive Load
100A(NO)/ 30A(NC) @ 12VDC Inrush Current
1A @ 5VDC
1.51W
Plug-in ISO
Genuine Rolla
Its PETEY PETE, y0!
I think that should be fine man. Technically, its not recommended to do that because you "could" eventulally "fry" something, but I haven't had a problem with increase the fuse size a small bit, that you want to do.
The relay's should be fine.
