evan2 said:Use no gasket.. METAL TO METAL IS the best GASKET ever.. you just have to make sure both surfaces are flush
i had no gasket on my wg.. its not a big deal
metal to metal is best my man
Yea I know it would be best, but this was a temp fix for a few weeks. It also worked just fine for that time. Im going to be redoing the hole turbo setup in the next few weeks, so I'll be all stright again with the set up.turbo95eg6 said:I would reccomend not using one as well. It can cause the bolts on the WG to come loose
UUUM about all of them. Do you have a problem with that. And if so would you like to help me out with a class or two ?Ravage70 said:better yet, how many english classes have you skipped?
i dont think RTV will work for a wastegate. Since there is no much. it'll just melt it.io_303 said:RTV is some good stuff, but be careful, it wont always hold
UUUHM Yea, we can tell........Ravage70 said:im the king at being an ass
thank you
Well I do understand where your all coming from on this, but the red RVT worked like a champ... I know nothing is better the plane ole metal on metal, but in a pinch it worked just fine..nd4sped said:i dont think RTV will work for a wastegate. Since there is no much. it'll just melt it.
