The more difficult to replace or time consuming, the higher the cost will be. A rear main seal and/or transaxle seal will cost a lot more than say, a distributor or camshaft seal. It's not going to be cheap (by my standards) to replace all your seals/gaskets but if you are adamant about it, consider replacing other worn components while you have the mechanic pull your engine and trans apart.
