gauge cluster install
stuffinopolis
not a noob
hey y'all. i'm buyin a gauge face cover from EK9, and while i have it out, i'm gonna do the v-tec activation light for my sohc on the gauge face. the only thing is, i can't find how to get the gauge cluster out. i know sombody knows how, with everyone's talk about puttin in ctr and itr gauge clusters and indiglows. i just can't find any write ups, and every time i try to take stuff apart, i always miss a screw or two. i tried looking up a hosted chiltons, but i can't find one that works for my gen. mine's a 98 ex coupe.
any help is appreciated
96greencivic
#1 in the Atlantic!
just be careful when you pull away from the two bottom clips. I broke mine off :( Still holds on tight though!
dinko
fa' sheeez
if my gauge cluster set on fire i wouldnt take my dash out again thats the gayest f**king most annoying thing u can do to your car
I HATE IT!
END RANT
stuffinopolis
not a noob
dude that was so easy dinko... took me like 15 min., and i'm a n00b. did break one of the clips, though. good call 96greencivic. i'll post pics of my gauges when i finish.
96greencivic
#1 in the Atlantic!
Let's see pics. Yeah, those two bottom clips are a pain. Oh well. still works though
GOOSE
JDM yo!
I HATE IT!
END RANT
how did u do that???
Lonestar
Honda Driver
*yank* *yank* -snap- "Oops."
I put the reverse-glow gauges in back in december sometime, but I was either too lazy or couldn't afford to go get a repair manual at the time. So the gauges are in, they just don't light up. I'll get around to finishing the job sooner or later.
freekaingjon
hey i got reverse idigauge too. can u do me a favor and do a write up on how to install it? i got everything down but i dont no how to wire it.
stuffinopolis
not a noob
if you follow the link UnitZero posted at the top, you can get the gauge cluster out. also in the write up in the link, it tells you how to remove the gauge faces. to install the gauge covers you have, you just take out the screws on the face, slide your covers CAREFULLY over the needles, and then reverse everything. to wire them up, i just tapped the two wires from the gauge face covers into the two wires that go to the light on the top ove the gauge unit... look at the attached pic. then i mounted the new dimmer switch near the coin tray.
dinko
fa' sheeez
RED wire goes to RED AND BLACK on your dimmer, BLACK goes to BLACK. if you have a silver? if you have a third wire you wire it to the ALL RED wire and thats it
your dimmer switch should just slide out (push it from the inside out once you have your cluster out)
ps dont cut too close to the plug...and the wires are gonna be a b***h to strip cuz you've got such little space to work in?!
hope that helps...pm me or email me if you dont get it
Lonestar
Honda Driver
Finally got them wired in after having them installed for 4 months. Now I don't know if this was exactly smart or not, but it works. Whatever.
Now I took out the gauge cluster again and found the wire leading to the stock bulb that lights the whole cluster. I cut those wires and used butt connectors to connect them right to the two wires connecting to the gauge power box dealie. Ta-da! Instant illumination. Turns on when you twist the light knob thingie, dims when you turn the gauge dimmer or the gauge dimmer from the car itself. Like I said, might not have been the smartest thing to do...
