Gauge Cluster Swap??????
b18c1hatch
I have a 95 civic dx and i got a gauge cluster from a 92-95 civic ex sedan and there are 4 plugs on the back. I know this cause i took it out, but when i went to put it in my hatch, the hatch only has 3. everything worked except for the tach. that was the whole reason for getting it. If someone could please tell me how to make this work i would appreciate it. Thanks!!!
Mr. Lin
Admiral Ackbar
Maybe the plug has retracted down into the jungle of wires behind the cluster... better find it... it should be there.
Bangin' HB
surfing member
http://www.clubcivic.com/board/showthread.php?t=7647
that extra plug (im assuming the green one) is for cruise, dont have it and it doenst make a dif. if the cluster isnt working then you should try wiggling the plugs. or just disconnect and reconnect to make sure they are in good. if still no worky, then you prolly have a defective cluster. they are plug and play so if something doesnt work, there is a problem
