eK4TheWin
Plz dnt teez the SOHC
Hi, guys! My goal with this thread is to build a sort of database that we can share with others about MAX mpg's that people can expect of their engines or swaps that they are planning on doing. Some of this stuff may be common sense to some, but I know it will definitely help others. So I will begin.
Engine: D16Y8, No Power Steering, Completely stock no bolt-ons or anything, 2000 CX Hatch
1. I don't rev, not even a little bit, when taking off in first gear.
2. I match the rev as close to exact as possible before releasing the clutch (this may serve more for clutch preservation than anything else) in an upshift.
3. When slowing down, I do not downshift ever.
4. I try to see as far as i can for a traffic light, and go into neutral to let it cruise. I had to FORCE myself to be aware of this, because I wasn't one to do a lot of neutral cruising. I always slowed down mostly in gear and went to neutral about 100 ft. before stopping.
5. DO A LOT OF NEUTRAL DRIVING! Be aware of your driving situation at all times so you can cruise at neutral whenever possible. You can sometimes speed up and slow down while in neutral without ever having to touch the accelerator or brake.
6. I shift at 2 to 2.1 RPM's and cruise the expressway at 55-60 mph. This took a lot of practice for me to cultivate the patience for this lol.
7. I run without AC. This uses more gas than the drag caused by driving with windows down (at least in my car.)
MY RESULTS: 520 Miles on one full tank (I didn't go until running out, but I ran it pretty close for this one experiment. It's not a good idea to make a habit of this).
TANK: 11.9 Gal.
Hope you guys can try this out and post (honest) results. I'm kind of interested to see what's posted. As always, thanks for reading and posting!
TANK: 11.9 Gal.
