Going from NA to Turbo B16a suggestions?
hooters851
I am currently looking to get more power out of my b16a and with my current parts it looks like turbo would be the best way to go. I would just like some suggestions on what exactly i would need. I have money to spend but if possible id like to keep spending at a minimum. I think a budget of around 1500-2000 sounds good. I got 240-whp on the dyno and would like more. Thank-you.
Current specs for my car are...
Engine b16a block
Eagle stroker crank 3.334 mm over stock
Hbeam rods
JE pistons 13:1 comp 82mm bore
Ported and polish b16a head
High tech header 4-2-1-
Exhaust is 2.5 stainless to a vibbrant muffler
Skunk2 valves+springs+retainers
Blox stage C cams 11.5 lift
Buddy club adjustable cam gears
N1 crank pulley
TypeR intake mainifold full ported and polish
Blox 70 mm throttle body
Eagle fuel rail with 550cc injectors
catch can vented
:welcome:
13:1 is pretty pretty high ratio... Boost doesn't play nicely with high compression unfortunately.
What's your power goal?
Look into some Go-Autoworks stuff for turbo parts. Greg is a great guy, and very knowledgeable.
For what you have now though, your budget is a little on the cheap side. $500 alone should go to tuning alone. You can fit your budget it you look around and piece a kit together, but you'd probably also be dealing with some used parts.
CHILD
All Day, All JDM
Those pistons and camshafts aren't going to go well with turbo. 2 grand is a low budget considering where you're starting with this built b16.
