The seats aren't certified for race, the harnesses are probably expired, and unless you're going to put in a roll bar and a harness bar, then it goes without saying you're toast in an accident.
werd, running 4 or 5pt harnesses without a rollbar/harness bar is one of the stupidest thing you can do.Eran said:I don't think you get it.....
Those seats aren't certified for anything. They're probably far less safe than your stock seats. Does your RX7 have a roll bar and a harness bar or a cage? Because if so, you run into the same safety issues. I mean, if you'd like to ride around with piss-poor quality safety equipment, be my guest, but don't expect anyone to feel bad when your spine gets compressed because someone rear ends you.
if he was TRULY worried about saftey... he wouldnt have bought a honda civic....Eran said:I don't think you get it.....
What would he have bought then? Smaller cars are much better designed than big SUVs and trucks as they actually have to pass certain tests,also you can manuever more easily around obstacles instead of hitting them head on and hoping there is enough solid metal to protect you. Not to mention Honda has had some of the best SRS systems for quite some time now.$lick Rick said:if he was TRULY worried about saftey... he wouldnt have bought a honda civic....
he drives a soda can with wheels
give a tin can a great srs system and good handling... and it'll still be crushed like a tin can if anything larger comes in contact with it\\ Forgiven // said:What would he have bought then? Smaller cars are much better designed than big SUVs and trucks as they actually have to pass certain tests,also you can manuever more easily around obstacles instead of hitting them head on and hoping there is enough solid metal to protect you. Not to mention Honda has had some of the best SRS systems for quite some time now.
that's similar to what that football player said before he got plowed by oncomming traffic on his motorcycle\\ Forgiven // said:my whole point is, I wouldnt hit you head on because my car can outmanuever yours.
