Good turbo Kits
str33tpr3p
What are some good turbo kits that are under 2000$ that wont crack down , Not looking for anything of ebay .
Looking to run about 8psi of boost on stock internals
str33tpr3p
And it will be for a d16z6
eg6white305
I had a greddy 15g turbo kit with greddy intercooler and bov that i bought used for $ 900.00. Was very good quality but the turbo max's out at 250whp. Very common kit that alot of people have used for d16's with great results. Good for low end, turbo spools up by 2000 rpm.
Kensai
8psi means nothing. What is your horsepower goal?
It looks like you have some researching to do before boosting your motor.
Here's some info:
http://beesandgoats.com/boostfaq/g2icturbo.html
I would recommend piecing together your own kit, that way it will cost you less and you will know that all the parts are reliable.
New brand-name kits cost $2,500-3,500 generally...
Check out spoolin-performance, full-race, go-autoworks as well as your local classfiends forums.
str33tpr3p
Yeah i do need to do some more research i know, And alright that sounds good i was thinking of putting together my own kit thought it might be more expensive. And my goals are around 200 horsepower .
Kensai
200 sounds reasonable, you'll also want to upgrade your headstuds to ARP and get a new OEM HG. Make sure you do a compression test to make sure your motor is in good shape.
str33tpr3p
I know it is but it never hurts, do you think its a must to replace the headstuds ? Or just highly recommended ?
eg6white305
Installing arp headstuds is pretty easy as long as you have a haynes maual. It is also a good oportunity to inspect cylinder walls, pistons, and your valves.
