so it sucked but long story short i had to part ways with my white coupe. i looked around craigslist and found this for $750 spent $900 after taxes and transfers.
95 civic ex
needs alittle work needs a real wheel bearing, a tie rod end or ball joint up front alignment . sunroof hits car, drivers window dont go down. cuts up under load after 3500 rpm badd. paint is chipping from horrible prep work.
the good no rust.but a nickle size spot on qaurter
it runs.
jdm d15b block d16z6 head
chipped ecu
clean interior
good glass.
full exhaust
perfect project for a cheap ass price
more pics when i tear into it tommorrow..
The motor before i toyed with it today
Ngks i bought foe my white car only ten mins of use dropped in today
New fuel filter, fuses, and some mystery oil
before
the engine bay now new radiator stay, intake, got rid of fan wires to toggle.
new oem fuel pump replacment
so hear we go the car had and extra map hard wired into the ecu. pulled it out and soldered and heat shrunk the wires.
befo also vetec wire looped
after
installed a rear strut tower bar.
pulled the old fuel rail and injectors off. three of the four were cracked on the bottem and the fuel line was backwards from rail to filter. changed the oil cap also.
guess what she runs solid now.
A random pic from today
so my idle is loopy figured id pull apart the throttle body and clean the fitv or w,e its called lol
cleaned it up some
oh yeah look what else i did
also found two things today when i washed car that i like alot
thin side moldings
also antenna delete
Oem power mirror and cruise control block off
got some awsome news, went to insurance yard today and it wasnt as bad as i thought so.
the relocation of the battery was done horrible and caught fire, i replaced, battery and power and ground cables, starter and fuse box and guess what shes backk!!!!!!!!!!!!!!!!!!!!!!!!!!!
went to the car wash and washed all the salt and grim and stones off and under it
I got a few fender washers going to pick more up sometime
installed my fender washers today, on the headlights and ground now i just need 40 more lol
removed rear seat belts
Heres a pic of how it looks empty.
95 civic ex
it runs.
chipped ecu
clean interior
good glass.
full exhaust
before
after
cleaned it up some
thin side moldings
also antenna delete
