Alex.yoas
First time doing any engine swap so I'll start with what ive done then where I am and what I want to learn to make this all correct.
Had a D15 in my del sol before swap took the pos and threw in my B18c1. I had a parts car I was getting some parts off of since the block was blown and the "parts" car was I believe OBD1 and the motor I bought to put in my car was again I believe was OBD2. so the parts car I got had wiring harness and OBD1 ecu so I decided to swap my OBD2 engine to OBD1 since the parts I had were that and my car was already OBD1 (Don't know if my car being OBD1 mattered)
So now my B18 is in and mounts are looking good.
Problem 1. I don't know where the positive cable to the battery was wired on the parts car since I took it all off. on my D15 its in the wiring harness but on my parts car harness it's not on the harness.... I cant even find my positive cable. suggestions and pics please.
Problem 2. My throttle cable I cant find out how to run this wire. I only have the stock one from my D15 but it seems a bit long but it does have a bracket that's attached to the driver side wheal well.
Problem 3. I have a cable from my wiring harness that doesn't have a plug in on the driver side. I also have one that would fit it on the passenger side. There are a few plug ins (male and female) that all fit these connections so my question is, if the male plug in is same in 2 areas does it matter what wire plugs into that female plug?
Please understand this is my first big project, I did this 90% to learn so if my question is simple or stupid take that into consideration.
Ill make a forum after its complete of all the pictures I've taken. once the motor is done and running I have plans for the rest of the car.
