Red97delsol
Hey everyone i have a 97 gsr trans on a 95 gsr motor in a 97 DEL SOL and it will not shift into gear while the car is running. When the car is not running it shifts smooth into every gear. I have a New Fidanza 7.5 lb flywheel, oem honda clutch and a used ACT pressure plate. New OEM pilot bearing, OEM throw out bearing, New shift for and spring all OEM. I have a new OEM vtec b16 del sol shift linkage. Ive bleed the clutch lines a total of 3 times now i adjusted the part on the Clutch master Cylinder that goes to the pedal and you put the pin through to it is closer to the pedal trying that. I got the trans in about an hour go and still wont shift into gear while running. I Put it in reverse and then started the car and with the pedal fully pushed in it jerked and i threw it into neutral not wanting to f**k anything up. Please help. And the car motor wiring and everything is good. Just the trans is f**king killing me.
Thanks Jayden
Thanks Jayden
