gsr turbo dyno
civickid81290
Just got my car dynoed. Gsr block with b16 head completely stock with 2.5" exhaust and t3t4 turbo. I put down 260 whp and 172 wtq at 9.5 psi. Are tho
se decent numbers?
Shiznit
Stickin it to the Man
specs on turbo?
AE Motoring
try doing a 3 inch exhaust, should put out more. i had stock GSR on 9.5 pounds made 306 and 220, but
Is this the kit you bought like 2 weeks ago? If so, quick install!
31dev31
Chillin' Canadian Member
x2 with a larger exhaust piping, it will help the turbo spool up faster and you will get more flow.
civickid81290
its a 57 trim. Yea its the same kit, but with a new turbo, the one that came with the kit was bad.
Kensai
2.5 or 3 inch DP? The numbers seem okay, not too low and nothing too phenomenal.
azandford
i made about the same power on my setup although im running a small t3 turbo with a 2.5Dp and 2.5 exhaust
sometimes has to do with the tune my tuner likes to tune fuel on the fat side so it'll make less power but be more reliable since theres less chance of detonation because its running to lean
civic92si
Gina my Lady in red
eekk.. on my GSR bottom end built (lower compresson 9:1 pstion rod) i put down 317whp.
u should of put down more......since u have higher compression and im at 10psi.
