Yes i searched, every thread i found was fuse related, or just people with stupid questions. I've spent time investigating this and cannot figure it out.
Alright, heres the deal.
I swapped an LS Integra cluster into my ej8 2 years ago, and it's been doing great, no issues ever. Until thursday night.
Thursday night i went to start the car after installing a new clutch master/slave, and doing a valve adjustment. The battery was dead and the ECU main relay lost power (you could hear the 'click' when they'd loose power). No biggy, happens all the time (i have an odessy battery thats 3 years old) so i jumped the car and first time i fired it up nothing on the cluster was working but the battery light would come on then shut off (like normal, on ACC position). So i shut the car off, fired up the truck i was jumping it off of and let it run for 10-15 min then everything was back to normal on my car. (parking brake light was on, check engine light cycled, turn signals work)
Next morning i start it to go to work and back to the same BS that was happening the night before. I pull the cluster out and blow off the connections, check all the wires i can see/feel and make sure all is well. Plug the cluster back in, fire it up and everything works normal. It does fine the 3 miles back to my house from work.
Go to leave later that night and as soon as i get to the end of the block the whole cluster went dead (temp, fuel, rpm, speed, all lights info related ie: check eng, battery, parking brake, oil, turn signals) then as i got onto the highway (had a friend following me setting the pace) the cluster would come/go and TRY to work. The RPM's/speedo would jump up to right about how fast i was going and sit there for a split second then drop back down and either sit at 0 again, or jump between 20-40, etc. etc. It was always random and never between any set RPM/speed range.
I noticed when i'd hit the brakes and start slowing down, and got to around 30mph (decel) the cluster would come back in and work fine. However, acceleration from a stop the cluster would wig out as soon as i revved the motor to start moving. Also, my hazards still work but my turn signals do not always work. And my signals do not come/go around the cluster. Sometimes they'll work when the clusters working, sometimes they work but the clusters not working, and so on. Again, it's also completely random as to when they do/dont work.
So;
I've gone through ALL of the wiring i can get to without pulling the dash out, I've checked all KNOWN grounds (steering column, under kick panel behind hood latch, on center dash support, and by main relay)
I've checked all fuses related to INTERIOR electronics (radio, clock, instrument lights, back up lights, alt fuse, battery fuse etc.) and all look to be OK and are tight within their socket.
The car still runs fine (vtec works, 2step works, etc.) which tells me the ECU is getting all of the information, but the cluster is not receiving the information consistently like it is supposed to.
So i am at a loss, and i need to get this fixed today as the car goes back on the dyno for more tuning tomorrow. Hoping i wont have to pull the dash, and the whole engine bay harness and start going over everything in order to fix this.
Any helpful ideas/input is greatly appreciated!
Thanks
So;
Thanks
