90-00 integra passenger axle
90-00 integra driver axle
94-97 half shaft with driver cv cup
(You can use prelude also but accord is cheaper and easier to locate)
Yonaka motor mounts work just fine for $120 w/ 90-97 accord f22 vtec t-bracket
Run the alternator power wire along the core support through the inside of the passenger fender (cleaner look)
Extend the 4 wire alternator plug, highly suggest going to a junkyard and cutting a good length
Ebay sells a dizzy that has the square plug. I recommend changing the ignitor with oem and your good.
I recommend a traction bar even if its a ebay one for $120. Eg, dc, ek all the same.
Shifting cables
2 ways to run it.
Under your heater core is a rubber cover
Or
Remove your srs (air bag ecu and the bracket) drill through(i highly recommend this)
Shifter, id stay away from the plastic box(97-01 preludes) and go with the metal shifter from the 92-96 preludes.
Or run a ktuned billet box or rsx plastic box with cables and ktuned conversion bushings.
Obd2-1 jumper harness
P28 ecu
Phearable basemap to get to a tuner.
If more ppl are interested hmu or post and ill take some time for pics
