No, get an obd1 ecu with hondata s300Thanks for that, to easy, so em1 ecu with hondata s300 would boo good yeah?
just found out.....I had already told you to use an OBD 1 ECU...a P72 is an obd 1 ecuwell i was going to run the h22 box also just found i should use a p72 with hondata whats advantage of using the b series box remeber the car will be race car only no road use
You're in for a ride dude. H series swaps are notorious for being a good amount of work. I've not done one, though, so I can't give you any advice.so am i right in thinking all i need is the h2b kit to do this and i all i have to do is swap the motor and bit of wiring sounds to easy any suprises i will come accross????
