dajailbreaka
o I started it today - the vacuum leak no longer exist , but it still had idling problems. On a cold start It runs perfectly fine. The vacuum is steady and the idle is at 1200 rpm and the car is building up oil pressure around 50psi- it's not until I push the gas pedal and rev it up it starts messing the up- the oil pressure drops. Vacuum going unsteady from 5-15 and then the rpm goes to 500 - I don't know what could cause this- the only check engine code I have is p1259 which is vtec so that can't affect it - I do not have a knock sensor installed, because I am not getting a cel light for it - but I did just order one to install , but I'm not sure if that would make a difference . It's a 1996 Honda civic with a p2p ecu with a d16y7 block and exhaust manifold and with a d16y8 head And intake manifold
I recently did the MiniMe Swap so thats why i am having these problems
Any help would be great thanks
also on idle i hear a hissing coming from the air intake ( is it taking in too much air?) i dont recall hearing it that loud before
Thing i have tried:
Bleed coolant
check hoses going to IACV to see if the right lines were hooked up, both of the lines were coolant so we are good there
reseting the icy _ drove around until hot then unplugged battery and then let it idle for 10 min( during this is bled the coolant)
What else should i try?
Thanks
Thing i have tried:
Bleed coolant
Thanks
