screenname
Honda Civic / 1993 / DX 2dr auto.
My Headlights switch back and forth when I pull the normal / High Beam lever on the steering column. (doubles as turn signal, turn signals not effected.)
Specifically, when headlights are in the 'on' position, one is on, the other is off. I can toggle between driver side and passenger when I switch the high beams on and off.
Both lights will stay lit if I hold the lever in the high beam position.
I have changed the bulbs, No effect.
I have changed the combo switch. No Effect.
Has anyone encountered this problem?
