Heads
Mark7901
Can I put a d16y8 head on my d16z6 block? Would this help or hurt? It should increace compression correct?
1995honda04
skunk2 man
will you gain hp?
Mark7901
I dont think this will gain hp 1995honda04, this would be strictly for compression......
$lick Rick
TEOTWAWKI
why do you think it would raise compression? a thinner hg might raise compression slightly, but i'm not sure about the head. any gains if at all would be un-noticeable and not worth the money/time
Mark7901
I was told that if I put a d16y8 head on my d16z6 block that it will raise compression by 1.0 to 1.3 higher. I was wondering if anyone knows if this is true, or has done this...
$lick Rick
TEOTWAWKI
it is BS i do bleive. the d16y8 has only 2hp over the z6 and that's not all due to the head.
Mark7901
Thanks! Basically what type of compression do I want for 10psi....I have around 9.2 to 1 or somthing like that....
bklynEG
FTW!!
i heard its only .5 raise in compression but its more efficient. the quench areas are totally different on each head doesnt matter if its obd1 or2
slammed_93_hatc
NoR*CaL knowledge b***h
ya the combustion camber can really effect the compression i dunno what it would be though
Handlebars
None Taken.
the y8 has a smaller combustion c hamber, thanks to integrated quench zones. the y8, along with the later h22a's, are the only honda heads with quench zones. it will raise compression, and it will gain some hp. the y8 and z6 are similar, but the y8 has a much better flowing intake manifold, while the z6 has superior flowing head ports. a P&P job on that head while its out will help out hp.
$lick Rick
TEOTWAWKI
so in your opinion is it worth it to swap the y8 head onto the z6?
Handlebars
None Taken.
no, the gain in hp is minimal, and the hassle of messing with the obd2-obd1 garbage far exceeds the gains. a p&p job on either head/manifold will result in a much better head than swapping one for the other.
$lick Rick
TEOTWAWKI
very good explination. thanks
