Have been doing A LOT of research, looking at what everyone has and I'm not sure if I need to replace everything or what.
Background story: Never tried the heat really when I bought it (in June), could have been blowing ambient air and I would have been like, "Yep! Works." Driving last night in 5 hours of snow storm at 35mph with no heat and no defrosters, etc, was a blast.
This morning, I had a ton of condensation inside, which I've never seen before. Could have had something to do with all the snow inside, whatever. The floor is damp where there was snow (driver's side) and passenger side had condensation (little bit) under the dashboard, on the blower.
What I checked:
- The temperature slider gets about 90% over to the hot side but never hits the end. If you push it, it kinda pulls back to that 90% spot. I tried adjusting it from the valve in the engine bay, same thing.
- Radiator is topped off, could probably be flushed, I'll admit.
- Hose going to the valve to the hose going inside, both sides of the valve are warm. Hose coming out of the firewall to the little block with the hose to the manifold and the bottom of the radiator is cold. The hose going to the bottom of the radiator is also cold, as well as the hose going to the bottom of the intake manifold. All 3 of the hoses coming from that little block with the sensor and ground on it are cold. (Car was running with heat on blast for about 20 minutes AFTER reaching normal temp)
- Yes, the car reaches normal temp (hair below half on temp gauge)
Where do I go from here? Can a flush resolve all of these issues? Does the valve need to be replaced because of the temp setting shorting itself on the hotside?
Anything I might have missed or any other info I need to post, let me know.
Thanks in advance.
What I checked:
Thanks in advance.
