Help changing the turn signal speed, make them blink faster
Sleeper
92 4doorSleeper
They blick fast only when you have a blown or missing signal... such as if your front left signal is blown then your rear left signal & dash indicator will blink faster. or like in a Accord or 4th gen civic if the front left bumper light blows then the upper front left & rear left & dash indicator blinks faster... sorry this is not a mod just a blown light
CivicDX94
thanks for the info, although i am curious because i see the faster light blinkers around town all the time. and i live in a small town (3x3 milies) so either there is a mod, or there are a crap load of lazy people with burn out lights.
io_303
NIFOC
for starters, go to radio shack and buy a 1k ohm pot.
1. remove blinker relay from fuse box
2. remove cover from relay
3. using a DMM, find the 100 ohm resistor
4. cut resistor off board, leaving enough wire to solder small lengths of speaker wire onto
5. solder speaker wire to board
6. solder other ends of speaker wires to terminals on pot.
7. reinstall blinker relay
8. turn on turn signal and check out what happens as you adjust pot
05
Show Me Them Titties
im surprised no one told him to check his blinker fluid
io_303
NIFOC
it was tempting to ell him to get some MAD JDM fluid, but I knew the naswer so i said that instead
TorGa3iGhT
"torga eight"
i have a hyper blinker on my civic...something like 4-6 blinks/sec...just go on ebay, look up hyper blinker or something and match it with your car. Then once you get it, take out the relay (black box located near the fuse panel under the driver dash), and replace it with the hyper blinker relay. Then it should blink faster.
If you dont know which box to remove, simply turn on your car, turn the blinker on, and feel for the pulse near the fuse box. The one that pulses with the signal is the relay that you will want to remove and replace with the hyper blinker.
bmoua
dude..i thought u just had to buy a smaller bulb that puts out a lower amount of watts...i've tried finding it..but..can't do it...though the older model cars car it....u can cut wires and all that stuff but..u can just buy a new bulb...
Grafix Ink.
just get an led turn signal replacement bulb...
you'll get that crack head / racer signal ur after...
TorGa3iGhT
"torga eight"
i haven't heard of this way of doing it...naw, i just bought the relay box for mine...seriously, it took 1 min to put in...no tools/experience required the way I did it, and my blinker/hazards are super fast now. =)
Sleeper
92 4doorSleeper
Its a great way to get pulled over. Its a sign of a blown light & a reason to be f**ked with the police
TorGa3iGhT
"torga eight"
i've never been pulled over for using a hyper blinker...my friend has one too, and never been pulled over for it.
I dont think in the police codebook it says anywhere about blinkers having to be a certain speed. It does attract more attention, but i dont think believe they can write you a ticket for it.
Sleeper
92 4doorSleeper
s**t, here in Va youd prolly get billy clubed upside the head for having it.... state laws differ btw
TorGa3iGhT
"torga eight"
yeah,i know...i just figured since the guy who was asking was from CA, it would apply, since i'm from CA as well. =)
Going-West
Tree people on my radio
how much whp does it give? :shock:
Beelzebubba
SubGenius Member
This moment in great ricer mods brought to you by CC!
