HELP! fog light question
EH2 GSR 7232
Dee Dee Dee
Has anyone ever wired up the factory fog lights for a 92-95 using the factory wiring but with a regular toggle switch? cause I have myself all confused here trying to get these things in. or does anyone have the wiring diagram for the factory fog lights?
a100100
you should use a relay. set the switch to send power to pin 85 or 86 (depends on which one you chose as ground, basically make sure they are opposite). youll want to run your power from an ignition source, not constant. pin 30 is your 12v out to the lights. the center pin (if its a standard bosch style 12v relay) is not used and i cant remember if its 87 or 87a. whichever pin is left, should have 12v run to it.
