Through experience the hot no-start on Honda's have been due to a failed ignition coil. They expand when really hot (10+ years of use) and then contract when they cool down. Not to say this is your problem but its a good place to start as the coil is a primary component of the ignition system.
You need three things, air, fuel and SPARK.
Pull the plugs one by one and see if you have weak, strong or no spark on any cylinder. If spark looks STRONG its generally a fair chance to OK the spark plug wires. However if spark is WEAK, check resistance on the plug wires, this is really easy to do so do it regardless.
If plugs and wires are good to go, check condition of the distributor cap and rotor. If you see a lot of green growies (arc deposits or moisture oxidation) If contacts look corroded, replace as needed. (DONT THROW GOOD PARTS AWAY! - TEST TEST TEST!)
Also check the ignition coil for resistance and short to ground. This tends to be the issue when I saw this specific HOT NO START condition. (I dont turn wrenches professionally anymore)
Lastly since you will have more of the distributor apart you can also remove and test the ignition control module at most parts stores, Oriellys, Advance, Autozone, etc., generally all have ICM testers.
