mr.scitals54
Hello
i found this eg6 forsale im not sure if its a good deal, can you guys tell me roughly what you think its worth its over all in ok shape outside 7/10 inside 6/10
here is the email he sent me
Im selling my turbo ls vtec hatchback, the head was assembled by portflow and the bottom end built by Jerrybuilt and tuned by church in LA. The motor made 367 hp at 14 psi. The car does have a clean title but no ac or ps.
rebuilt engine 5000 miles
b16 portflow assembled head, non ported
SuperTech SS valves
SuperTech dual springs
SuperTech ti retainers
3 angle valve job
new seals
gsr cams
AEM cam gears
stock sleeves
81.50 mm bore
cp pitsons
eagle rods 3/8 rod bolt
acl bearings
type r oil pump
arp head studs
victor x manifold
stock throttle body
all new oem seals
oem water pump
oem timming belt
gt3076r .63 housing
turbo xs boost controller
lovefab manifold
3 inch exhaust
38mm tial wastegate
50mm tial blow off valve
3 inch core front mount intercooler
slim electric fan
aeromotive fuel regulator
walbro 255 fuel pump
1000cc injectors
msd spark plug wires
new distributor
ngk spark plugs
golden eagle fuel rail
glowshift oil pressure gauge
glowshift boost gauge
hondata s200 with boost capabilities
p28-
tires up front are the nitto nt01
tires on rear are yokahama
converted to rear brake discs (brembo rotors)
ebc rear pads
power windows
legend 2 piston calipers 11 inch rotors from fast breaks
4 stainless steel break lines
1 inch brake booster
hawk blue racing pads up front
full race traction bars
endyn catch can
aftermarket radiator
tokico struts
tanabe springs
adjustable camber arms
3 inch downpipe
skunk 2 mega power muffler
SuperTech SS valves
3 angle valve job
new seals
gsr cams
AEM cam gears
stock sleeves
81.50 mm bore
cp pitsons
acl bearings
type r oil pump
arp head studs
victor x manifold
stock throttle body
all new oem seals
oem water pump
oem timming belt
gt3076r .63 housing
lovefab manifold
3 inch exhaust
38mm tial wastegate
slim electric fan
1000cc injectors
new distributor
ngk spark plugs
p28-
ebc rear pads
power windows
endyn catch can
tokico struts
tanabe springs
3 inch downpipe
