HELP installing subwoofer?
itsmycookie
#1 a*****e
well you;ll probably need an amp kit for your car. and a box, amp, and subwoofer(s)
ps - this should be in interior section. i;ll go ahead and get someone to move it for you.
1999stockaccord
Honduh's... LULZ
search, but basically you rn an amp power wire from the battery to the amp, ground the amp to the frame, run a set of rca patch cables and a remote turn on lead to the hu, then speaker cable to the sub box from the amp, or...
... buy me a round trip ticket out there and i'll hook it all up for free... =)
cujo613
And again my advice would be get in your car. Drive it to a professional. Pay them mnoney. They install your s**t right with a warranty.
Backyards are for bbqs not for installing stereo systems
charles_00Civic
CC'S Longest Running Noob
K i did it myself without any prior knowledge. Made my own box. K. Put the red wire from yuor battery (with a fuse inbetween, comes with installation kit), and take it to the subwoofer box. ON a civic everything screws off or pulls orr so putting it under the panneline aint a thang. There's also a few holed int he firewall to got hrough. Follow the on from the ecu, (left passenger side) and cut a hols smaller than the diameter of the positive (red) wire thourgh it. Run the wire throught there to the battery. Then, take the wire that is 2 parts with the little rca connect on the end and plug one end into the decks imputs and one end into the amps inputs. There's 2 plugs that look like this ont he amp. Use the one that isnt the passthourgh. lol. Black to white and red to red. Then take the small speaker wire from the kit and run it from the deck to the amp. Connect it to the amp by splicing it onto the blue wire with black stripe. This wire basically tells your amp when to turn on and off. Rca's go tot he rca plugs ont he deck. little acc wire to the port on the deck that says accesory or sometihng like that. Red to the b+ or + one. Then plug the other big wire into the ground on the amp. It's a nother little port. Ground it on the fram somewhere. The tailights have a big dscrew under em. Scrape away some of the paint and tightly ground the white wire to the frame. On the amp it'll have small ports. labeled + - + - for one sub wire take the wire from the first + on and run it to the + one on the sub. Then run the res tof thew wire from the - terminal ont he sub back to the amp where you'll plug it into the 4th terminal (-). Make sure everything is tight. tjhen fire her up. On the back of yuor box there might be little clips. Thats so you can run the apeaker wire to the clam and then to the subs so the box can be removed easily. I just drill hole sint he box and run the wire through. SMALL holes though so no air can get out. Then you dont get any distortion at all.Make sure everythig is tight and fire it up. lol
isak
ok so, i tried installing it but it failed.... =/
i connected battery to amp with fuse in between, i connected pre output from my deck to the amp input, i connected a remote wire (i think it was a remote wire, not sure. maybe this was the problem to my failed installation) to my amp, then i grounded the wire from my amp to the car.
i have a panasonic deck and an infinity amp.
when i turn on the deck and battery of my car, the amp turns on and goes off in about 3 seconds, i have no clue why....
can you help me???
cujo613
get abetter ground, scrape all thepaint away until there is bare metal and ground within 1 foot of the amp.
96greencivic
#1 in the Atlantic!
Ditto, sounds like your ground is bad.
charles_00Civic
On panasonic amps the bue wire with black line is the one you want. If iot turbned on then thats opkay
u'mm make sureyour sonnections are thight. Check the fuse. It may hsve blown. Mine did firt time around. Make sure the grund has NO paint around it and is tightened very tight.
Shiznit
Stickin it to the Man
does it turn off? or does the green on light turn red
isak
well it turns on and it just turns off. do i need to do anything with the "acc" wire??
