Help me do my turbo build.
stince
I've talked to a few people..
and i've deiced to go sohc turbo on my new hatch.
From what i've been told.. this is what i want.. and need help finding.
Turbo .53 trim tops .48 out
Manifold - Log style
FMIC (not too big)
RFL bov
DSM 450's
Y8 Manifold
Down Pipe and piping
help me out.
Evan.
iTrader EVERYthing
what type of turbo? t3/t4? t25?
wastegate?
how are you going to tune it?
watisjdm
Clit Commander
more specs...and what power goals u want and etc and we can help ya out more
stince
just lookin for 200-250 wheel horse..
T3/T4 53 trim area... not too big but not too small
lOg manifold..
DSM injectors..
watisjdm
Clit Commander
try a gt28r that will max out at 300 and it spools quick
Evan.
iTrader EVERYthing
what are you tuning with?
swappedcx
If John is going to "tune" it then its not a basemap. He will probably run uberdata.
Besides the obvious that was posted your still going to need the "little shits" that start to add up in cost when you forget about them....such as oil feed and return lines, oil T, couplers, clamps, i would reccomend getting a boost gauge and at least a oil pressure gauge. Also need to decide if your going internally gated turbo or externally gated...and if you need a boost controller or just running off the wastegate.
--<EM1>--
boosted ftw
measure twice, cut once. do lots of research (which it seems youve done) and do it right once.
stince
yeah, jon runs uberdata.
I know the lines, clamps, wastegates, turbo timers, controllers, gauges, and so forth..
i also need sites and places to locate these parts
Phantom Civic
Never Satisfied
lOg manifold..
DSM injectors..
The log manifold will help your spool time. I would look for 190-240whp though, 250whp is really pushing it for a DD. I would recomend a 50trim t3/t4 if you want a semi good spool on a budget and still room to play with. If you want an all out motor later on the go ahead and get a 57trim. If you never want to build, something like a .42/.48 t3 will be great.
All that is on a budget though. If you want "the best" get a gt28r for a stock motor, gt28rs if you want to semi build the motor, and either a gt2871r or a gt30r if you want huge power (for a single cam).
swappedcx
stince said:
wheres a good place to pick up these items.. i = hate ebay.
Buy used stuff...save the money.
I have a FMIC cheap if you want it. I see John all the time at school and you live near him...so shipping is nothing.
ryan89crx
Spoolin single cam!
200-250? use a t-bird super60. you can get them for under $200, will spool very quick, and easily support your goal
no sense spending upwards of $1000 for a turbo when something 1/5 the cost will achieve the same thing
Blk05Civic
Reppin HX
resistor box with the 450s? stainless steel oil lines, wastegate int. or ext. , what type of ECU/tuning?
jcwhitney.com for piping
find some cheap DSM 1g BOV, does the trick. get it welded.
and btw craigslist.com is your friend
