Help needed
luvsspeed
I have this problem that I need help with. I have a built b16 with dart sleeves (its not a dart block). Everything on this block was new. I have oil pushing through the oil pan gasket. Its been doing this from day one. My builder has known about this problem from day one and he has no clue what it could be. Now I have tried seval things, In order first I have changed the oil pan gasket twice, I have installed the endyne breather kit. None of those things has helped. I will be installing a new moroso oil pan on monday to see if is the oil pan. Now with my luck with this car I almost know this will not solve the problem. If anyone can point me in the rite direction or help me out, will any input??
--<EM1>--
boosted ftw
it seems like a simple fix but i guess its not. my friend had the same problem. ill ask him what he did and ill get back to ya.
sohclubkid
Sick 6/6
pan gasket is kinked, oil pan is warped... only 2 thing i can think of. good luck man!
luvsspeed
I'm going to change both 2morrow....I hope it works, cuz I dont know what to do anymore....thanks
--<EM1>--
boosted ftw
did you ever get your problem fixed? my friends oilpan was warped so thats what caused his leak.
luvsspeed
fixed it was 2 things. one the oil pan was warped and two the valve cover gasket was leaking behind the timing belt cover
