Help Viper 5002 Add-ons connect?
Karado58
Diodes and Relays on a Viper 5002??
I have a 1998 Honda Civic EX Sedan 5-Speed
Installing a Viper 5002 alarm system
Add-ons:
Tilt sensor 507M
Glass break sensor 506T
Backup battery 520T
2 Piezo sirens
I am totally confused as to the using of diodes and relays, or if they are even needed on the above setup?!
Can someone please simplify if they are needed, if so where?
Please do not tell me to have it professionally done, if i had the money I would not be here asking for help.
Thank you in advance.
eskateboarding7
You need to have this professionally installed.....I doubt you know how to diode isolate instant triggers......that's going to be required to hook up all those sensors.
Karado58
Please correct me if I'm wrong, but, I only need to use "diodes" anytime more then one sensor is plugged into the same input?!
Since the alarm has 2 Sensor inputs, and I am only using 2 add-on sensors (tilt 507M & glass break 506T) and plugging each one into its own sensor; i need not use diodes?
Thank you.
