HELP!!!!, white smoke, liquid out of the exhast and NASTY sounding idle
blackcivic95
HELP ME, ok, i tried to install a new TB on my 95 dx d15b7 last night, it was a ls one, and when i got it on i had a high idle like at 1800 and when i reved it it would go up to say 3400 and then STAY like the thorttle would stick but my pedal would come back down, the engine was also running quite rich because i could smell gas, well neway it was late so i decided to just deal w/ it later and put my old one back on well when i reinstalled the stock one, it got rid of all the problems except that it is still running VERY VERY rich, i have lots of white smoke comming out of the exhast and it sounds horrible, much deeper gurgling type sound, and is uneven, jus tlike bluhb, blubh blubh, nasty, and im sure that im runnin rich still smell gas and at one point when i reved the engein to about 3k some liquid came out of the exhast, couldnt really tell what it was because the smell of the smoke was so strong that i couldnt really smell the liquid, anybody have ANy idea what may be going on???? im completly clueless, i tried resettin my ecu but to no avail, im throwing no codes on the CEL light but ive heard there may be codes any way the light jus isnt commin on anyway yea any help guys?? thanks!!
by the way if anyone has neideas on the othe problems w/ the LS throttle body i would love to have ne help, cuz i do plan to get it back on, just wanna fix this problem first! thanks
kellog
blown head gasket is a sign of white smoke
gents97civ
White smoke is usually a sign of water/antifreeze burning. You didnt mess with the head any did you. White smoke is usually the head gasket.
blackcivic95
all i did was take off the tb, put on the new one, take the new one off, and put the old one back on, only messed with the throttle body and its compontents, if my Throttle cable is to tight will it send more fuel?? makin it run so rich? im just really frustrtaed and pretty lost. Irks me i went and messed w/ my car that was runnin fine and now i have a problem that dosent seem to have nething to do w/ nething i meesed with
SiGSR
yeaaaay.
Most likely what they said, a blown headgasket. Running rich would have you blowing out black smoke. Check your oil to see if it's mixed with coolant.
Having the thottle cable too tight will indeed make you have a higher idle.. more fuel consumption.
blackcivic95
how in the f**kin world did i blow a head gasket while messin w/ the thorttle body?
tonyM
caca poopoo
blown head gasket
buzzbombtom
captin sleep0
you might not have blown it from puttin on a tb but it could have just been its time.... just a conisdence. sorry. does your temp go up?
mugen_tuned
4G63-T
get the head gasket changed quick, im suprised its still running, once its goes, the car wont turn over. good luck bro.
mugen_tuned
4G63-T
if its just the throttle body you changed, did you misplace a vacuum hose with the coolant hose? check into that.
ccchondaccc
mmmmmm ta ta's
go with what mugen said and make sure all your sensors are back in place and working
SiGSR
yeaaaay.
... let us know what's wrong when you figure it out.
buzzbombtom
captin sleep0
mugen tuned you are way off just to let you know... you can drive a blown head gasket car for a real long time. my d was driven for like 300-600 miles it just ran hot.
mugen_tuned
4G63-T
from what ive seen bro, mind you this was on a saturn, the head gasket was fully blown and the combustion chambers got so filled with coolant that there was no compression and spark since everything was saturated. this is why i said what i said, heh. anyways, all cars differ in engine function due to its build.
Mirza95VX
***** of the VTEC-e
Yea u can still drive with a blown head gasket. Def get it replaced. I would do it as soon as possible cause u can start f**king up your coolant and even start leaking.
buzzbombtom
captin sleep0
yeah i drove mine to the point of combustion of the wire almost... that is when the car will stop running a d16y8 is this way a b16 not quite that strong but still.
