Help with cluster lghting
Sundown
Just go to Autozone or Pepboys and get the bulbs.. or Junkyard em lol..
Astheros
AMPhotography
r u forgetting the climate control?
2nedhnda
I ordered mine for Superbrightleds.com, cost me less than $12 and I did the guages and the climate control.
wtfh4xx
1337 Gold Member
okay, will I need anything else than bulbs to change the lighting?
And what bulbs are in the climate control?
oc_civic
as i stated in the other thread..
if you just stick in LEDs it will IMO and experience look sloppy.. there will be dim spots and bright spots.... the only way to resolve this is to take an approach that excedes plug and play...
wtfh4xx
1337 Gold Member
I was planning on splicing the wires and puttin in an extra #194 bulb on the cluster like you did.
Astheros
AMPhotography
oh and you only need the bulbs...not the little base as well since youre gonna remove the bulbs in your car and only put in the new led' bulbs.
ryanM
i coulda swore it was like 5 of the small ones and only 1 big one. anyways, i was completely dissatisfied when i swapped LED bulbs into my cluster, i ended up getting so fed up with the shittiness of it i bought an Si cluster. but i failed at putting extra bulbs in, i tried, but it didnt work, the bulbs always ended up being blocked off by something so no light got through.
oc_civic
i again stand by my previous statement..
plug and play = suck
the way i did it = stock light amount OR more
if you want your cluster to look like s**t (at least in my experience) swap to LEDs without adding extra bulbs...
as you can see in my picture.. the light is VERY even and disperced well...
wtfh4xx
1337 Gold Member
Thats why im questioning you. ;)
ryanM
like i said, i tried to put in more bulbs, and totally failed at it, wherever i added one the light was all just blocked by something :what:
oc_civic
right.. you actually have to CUT the cluster up to get the results i got...
wtfh4xx
1337 Gold Member
Im not worried about that!
Just tell me if I am right that I need 2 # 74's and 3 #194's!
