I have a stock 97 civic cx which I recently had a y8 tranny installed my issue when I drive at regular speeds the clutch engages fine but once I step on it from first to second you dont see the rpm drop its like as if I am power shifting it like slips for a split second then catches I bleeded the clutch and also replaced the slave cylinder and still no luck theres no leaks coming from my master cylinder but could it still be bad?
P.s I replaced my clutch and flywheel a year ago with excedy oem kit
