for the vacum, just cut into the gas lineJJup said:need help installing oil pressure gauge and vacum gauge there isnt a how to on eirther if anyone can help it would be greatly appreciated
greenlx777 said:for the vacum, just cut into the gas line
and for the oil, insert where dipstick goes[/Q
for the oil i have a pressure regulator where does that hook up to
JJup said:pressure sender my badgreenlx777 said:for the vacum, just cut into the gas line
where is the oil pressure sensor locatedgreenlx777 said:i was messing with you man.....
to hook up ur vacume line u just have to put this little ( T ) piece that came with the gauge, in between a air live, easiest one would be the little vacume line that passes threw the fuel rail
as for the oil pressure your going to need, ( unless you already have this tunner toys piece that plugs into where your original oil pressure sensor goes, so that you can connect the plastic oil line
on the back of the block, its got a little plastic cover over it, you need to remove it and install the adapter so you can connect a oil line to go to the gaugeJJup said:where is the oil pressure sensor located
hey quick q what color is the +ingition wiregreenlx777 said:this
goes here
and ur oil pressure line goes into tha
thanks dudeio_303 said:the ignition wire in the car is black with a yellow stripe
