help with HID wire
Ek4C707
Does anyone know where to get the HID wires that connects from the ballast to the stock wires on the car. The wire that connects to the stock bulb of the car. I have that wire but i only have the 9006 wire but the rest of the kit is h4. Or is there anyway i can rig the 9006 wires into our stock wires.
I need the wires at the bottom of the picture under the ballast.
THIS IS NOT MY PICTURE, BUT IM LOOKING FOR THAT WIRE THAT IS POINTED BY THE ARROWS.
thank you
wetcmonkey
thank you
it connects to your stock headlight harness did you not receive a black plug? If not you can just plug them straight into the stock head light harness
and yes that is ground
Ek4C707
That isnt my picture so i didnt ask if it was a ground lol. but i cant just plug it in the stock headlight cus i dont have that wire. all i have is the ballast and the bulbs so i dont have a wire to connect the balasts to the stock wire
wetcmonkey
who did you get it from, try a local dealer to find one. ebay maybe?
Ek4C707
Do you know what thy are called? if it the power cables?
AliasNeo
those plug into your old headlight harness. you know the plug with 3 inserts. do what they said above just push them directly into the slots. you will need to figure out the polarity of the slots and make sure not to plug into the high beam power.
wetcmonkey
thats the thing he doesnt have those wires, just try to contact the person where you got your set from or find a local dealer, use ebay, i know a site sponser should have some extra parts you can buy from him, and then again you can find a shop near by that would sells hid kits and you could get the harness from them.
Ek4C707
http://cgi.ebay.com/H4-9003-HB2-HID-Headlight-MALE-Wire-Harness-2-PCS_W0QQitemZ200316826174QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea3d0323e&_trksid=p3286.m20.l1116#ebayphotohosting
so i can buy that and just cut the other end and wire it to the plastic 9003 piece and it should work right?
if i do cut and re wire, do you know which wire i would wire it too, on the HID power cord i have for the 9006 has two wires that is black and red, which one do i wire to it.
I already cut the 9006 power cables up and try to stick them in the stock wires and it spark up bright them went to regular halogens then turned off.
