help with installing alpine hu in 96 hatch
IN2deep
Ok so first i got a 96 hatch with the single din sized opening for the head unit, and i bought it with a pioneer cd player and i traded it to a mechanic to put a timing belt on my car and he took it out and left the mounting kit, i got an alpine cda-9851 and a alpine module to go in it is why i traded the pioneer, so i made the connections from one wiring harness to the alpine and i connected it to the car and it worked but no stations picked up, but i cant find anything to plug into besides the white wiring harness i plug into the harness i bought that goes into the alpine harness, so problem 1 is i cant seem to find the antenna in? Problem 2 is i cant seem to get the climate controls out? i tried to pop it out but im afraid im going to break it? i saw the thred in the how to's but the dash is different than mine 1 and 2 it says there is clips but doesnt say how to get the out?
please help my dash is apart and i have no radio!
thanks
IN2deep
alright someone please help me get the climate controls out of my civic
j_fukin_t
pull the lower panels on the dash, i.e the one under the steering, pull the one under the radio/climate control, pull the glove box and empty because it will have to hang down, then start taking out screws in the panels, next there will be 4 screws that hold in the climat/radio bezel, pull them and slowly pull the bezel out and disconnect any wires that will hold it up
IN2deep
ok i got the lower dash where are the 4 screws? are they gold and going with the pointed end of the screw toward the seats of the car does that make sense like they are positioned opposite from the screws i took out in the dash, i removed some like that but it didnt loosen the climate controls and all 4 of these were at the bottom of the dash?
j_fukin_t
sorry for the late reply, the screws are gold and the pointed end will face the roof of the car
HP Civic 2
The antenae (sp?) looks almost like a small cigarette lighter plug in...Should be in the dash if you look under/in it.
**Edit 500 posts w00t :woot:
Brent878
ya you need to find your antenna wire, its seperate than the wire harness and you will get your stations back. Why do you need your climate control out, I am going to take mine out this weekend on my 96 hb and probably my 96 4-door. I can take pics if you want.
